Username: Lauchie411 Inverness,
Nova scotia
Post Number: 160 Registered: Jul-09
Wednesday, September 29, 2010 - 23:24 GMT I have a Phoenix and loaded factory U48 and then loaded V153.1 Then reloaded 154.2. Then i scaned the channels on 110 and all i get is the opentv channels. I check for IP and have all 00000000 and the last line has 255.255..... Any ideas as what to do , than you in advance.
Nova scotia
Post Number: 161 Registered: Jul-09
Wednesday, September 29, 2010 - 23:40 GMT Ok first to check can i get the Nfusion to work without public server?
Username: Mrskullz1 New York
Post Number: 1842 Registered: Feb-07
Thursday, September 30, 2010 - 03:00 GMT whats ur antenna settings? wht lnb do you have? what dish do you have? phoenix is up and running. May temporarily be down as of earlier today but should be up sometime soon. It also looks as if you are having a network issue and your stb is not getting a proper ip address. How are you connecting this box to this internet?
Username: Fwans089 Post Number: 20 Registered: Jul-06
Thursday, September 30, 2010 - 03:27 GMT Nfusion solaris is still down.
