Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 14 Registered: Sep-10 | wat brand should i go with orion, fi, dc, tc? which would be best |
Gold Member Username: TejcurrentPost Number: 2450 Registered: Apr-07 | How much power are you using? Tuning? Price range? |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 15297 Registered: Jun-04 | yeah power can be a big deciding factor |
Gold Member Username: TejcurrentPost Number: 2452 Registered: Apr-07 | Honestly the setup and box build will be the most important things- no one can say what will be best for your situation. If I was looking for 160@30Hz I'd buy different equipment than if I wanted 160@60Hz. And best SPL sub for 2000 watts is different than 20,000 |
Gold Member Username: Loc_outSoCal Post Number: 3244 Registered: Feb-05 | Money can be a big deciding factor. Having 200 buck or 700 bucks. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 3102 Registered: May-04 | I dont think TC should even be on that list. TC subs are waaaay more SQ than SPL. Dont get me wrong they do get loud but they are still SQ subs. IMO THE best SQ subs |
Gold Member Username: Extrmndor3Http://illuzonemu.serv..., ^^^Sick Game Post Number: 8299 Registered: Feb-06 | |
Silver Member Username: RosrockMichigan Post Number: 601 Registered: Mar-09 | ^^haha, no offense but the first post was kinda of pointless... we're gonna need a lot more info on your part. |
Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 15 Registered: Sep-10 | price is not a factor i just want a setup of like 4 12" subs tht will blow the trunk off my car and also im getting a alpine indash screen which amps should i use and yes i will be getting all aftermarket electric systems |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11411 Registered: Jul-06 | two DD 9515 and a sundown 3000d amp |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1388 Registered: Sep-09 | 4 of these would be 10k rms. http://www.soundsolutionsaudio.com/store/products/12%22-Warden-Series.html |
Gold Member Username: SkdooleyRoanoke, VA Usa Post Number: 1220 Registered: Oct-09 | I think M.S. has a good recommendation. That would slam. |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1389 Registered: Sep-09 | i like M.S.'s idea as well, and it uses my amp lol. |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 805 Registered: Jul-09 | No budget? Then why dont you do a couple 18''s? Or maybe a couple 21'' wardens? |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1390 Registered: Sep-09 | his key words. "subs tht will blow the trunk off my car" so it needs to fit on a trunk lol. |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16702 Registered: Jul-05 | if u have the $ then how about 2 : http://www.woofersetc.com/p9284/Z15-v2-D1--Sundown-Audio-15"-Z-v2-Series-Du al-1Ohm-Subwoofer.htm powered with 1 : http://www.woofersetc.com/p9251/SAZ4500D--Sundown-Audio-4500W-1Channel-Monoblock -Amplifier.htm if thats too much for u then http://www.audioque.com/aq/?page_id=72 2 aluminum coils 15" hdc & 2 aq2200d ... |
Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 16 Registered: Sep-10 | i do believe i am going to go with the digital design subs are they good for daily and what impedence sound i run if i go with the sundown 3000d amp and i might also have to hit bassman up for a box is tht recommended? |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16703 Registered: Jul-05 | yes they can be played daily i know the sundown 3k is underrated but imo id recommend some more power for those dd9500 like the sundown 4500d for both of them of course u will have to order ur subs in dual 4ohms ... |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 808 Registered: Jul-09 | I would definatly recommend bassman for your enclosure needs. http://dldesignz.com/ |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11415 Registered: Jul-06 | if you are going with the setup i mentioned you'd need dual 4 ohm or dual 1 ohm subs. and i suggested 15's assuming you could fit them... but most trunk cars can NOT fit the proper box for two DD 9515s... DDs need big boxes... maybe 9512s instead. |
Gold Member Username: Talon01Team dc audio, Pa Usa Post Number: 2182 Registered: Jun-07 | he could do 2 15" dc lv4xl's on that sundown 4500 that would be nasty and only take 6-6.5cf box |
Gold Member Username: Talon01Team dc audio, Pa Usa Post Number: 2184 Registered: Jun-07 | http://www.caraudioclassifieds.org/forum/showthread.php?t=55468 check this out! |
Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 17 Registered: Sep-10 | would like 3 dd9512s be louder then 2 9515 and which of the two have better sq |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11419 Registered: Jul-06 | it would be close but again you wont get the needed box space in a trunk... and i forgot sundown made a 4500 amp... so my new recommendation is 2x DD 9512 and sundown 4500d. and a hell of an electrical system. lol. |
Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 18 Registered: Sep-10 | ok lol what kind of upgradeds (brands included) would i need |
Gold Member Username: Gcs8Atlanta, Ga Post Number: 1403 Registered: Sep-09 | 1-2 alts, 2-3 good battery's, big 3, 2-4 runs of 1/0ga wire depending if you get CCA or OFC wire, and some booz for installing all that. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 11423 Registered: Jul-06 | HO alternator, good battery, and big 3 with 0 awg wire. HO alternators: motor city reman, db electrical, quality power auto. Batts: odyssey, stinger, sears diehard platnium (all odyssey made) Everyones going to have different recommendations on this topic, those are mine based on experience. |
Bronze Member Username: Basshead94Centralia, Illinois United States Post Number: 20 Registered: Sep-10 | what is big 3? and wat size alternator shud i get |
Silver Member Username: DomenicoBanginGMCArizona Post Number: 820 Registered: Apr-09 | ^lol |
Platinum Member Username: Rovin1 15 = 153 DBs ...Trinidad & T... Post Number: 16704 Registered: Jul-05 | for that system : buy the biggest ho alt that can fit ... |
Platinum Member Username: Insearchofbass2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ Post Number: 15345 Registered: Jun-04 | add dc sound subs to the list a lvl 5 beat a dd z direct drop in |
