Lyngsat
Username: Black_jack
Post Number: 87
www.lyngsat.com
did they close shop?
does anyone know?
Username: Satopia
Post Number: 477
hum i guess so unless its just haveing server issues
Username: Plymouth
Post Number: 14528
Work fine!
http://www.lyngsat.com/
Post Number: 88
Plymouth, I just open your Link and this came up
Oops! Internet Explorer could not find www.lyngsat.com
Try reloading: www.­lyngsat.­com
Maybe works only from Quebec City
Username: Satopia
Post Number: 478
it opened bud must have had a br@in f@rt
Post Number: 92
looks like Lyngsat is going
didn't even say goodby
I find it hard to believe
a great lose to the FTA Community
Username: Bernardmi
Post Number: 843
What are you talking about Iceman ?
Lyngsat web site is alive, well and living !
Post Number: 93
Man iam sure happy to hear that
How do you get in?
i have been trying all week
never had any trouble before
Post Number: 94
just tried it and this keeps poping up
Username: Runnerguy
Pluto
Post Number: 2155
It is there Iceman...maybe delete cookiies?
Post Number: 96
I deleted cookies still no go
I tried Google still the same message
very very strange
only Link that Iam having trouble with
Username: Bernardmi
Post Number: 844
Iceman. Here is a chance to try something different. That will propel your PC at warp speeds. Install Google Chrome on it. It will offer you to import all of your favourites used in Internet Explorer.
And you will probably be freed of your problems. You are likely to see Lyngsat re-appear !!!!!
Username: Bernardmi
Post Number: 845
Now hold on everyone.
I think I have found what Iceman is refering to !!!! Clicking to the link on your original message indeed shows NO Lyngsat.
But.... just type www.lyngsat.com into your explorer address bar and you should see it show up !
Username: Rtf
Post Number: 166
you need to have the www with this site
Username: Nydas
Post Number: 19581
Instead of clicking on a URL at Ecoustics, just type in www.lyngsat.com in your browser.
Username: Finish22
Post Number: 342
testing....
Username: Finish22
Post Number: 343
BTW.. Lyngsat's finances still look pretty solid too...
It is worth just slightly more than ecoustics!
( edit.)
Post Number: 97
Yeah Finish22 I didn't think they were finish hell they cover the globe.
Well I have tried every thing
I even did a System Recovery
very strange only Link that will not open
maybe Plymouth is behind all this.
I hate to part with the bread, but there is no other choice.
Well I need to thank all of you for trying.
I also did this about two or three times.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Username: Plymouth
Post Number: 14552
Iceman
Clean your ''cache'' then reset your browser to ''default''!
You just got a ''virus'' like Doreen send to majority of us!
Post Number: 102
Well you think you know about computers
try this for size.I just finish hooking up
my $1,000.00 hp and guest what I still can get www.lyngsat.com
could it possible be a defective Modem?
but why only on lyngsat?
another thought, could lyngsat have me block?
Username: Runnerguy
Pluto
Post Number: 2181
If you have a new pc that has never been to Lyngsat or any other site they cannot ip ban or block you from my understanding. This site could ip ban but they like the hits from anybody. They may delete but they pick up a hit anyway
Post Number: 103
I gave them no reason to block me
with my old pc never had any problem
the past 7 years to open lyngsat
I tried everything, so I thought it was my old pc
was getting old so I went and bought a new one
the wirest thing I ever came across.
Username: Harding
Post Number: 304
Sir, lyngsat site comes through nicely under Firefox 3.6 and Google Chrome. I do not have Internet Explorer, so I did not try.
