1991 Camry front speaker help
Username: Mkschenk
The front speakers in this car are only 3 1/2"
Can some one help me pick out a good speaker for that size, or if needed help me figure out how to make an enclosure for a bigger speaker?
I really do not want to cut and change the look of the car, it was my grandpas and it was garage kept all its life and bone stock, but i cannot stand the audio in it.
- Thanks
Username: Mkschenk
okkk... you guys suck
Username: Deadrx7conv
Be patient. This forum isn't too popular.
Use Crutchfield to outfit your car. Better quality speakers help but if you are size limited, then you'll have to break out the sawzall.
Username: Illuminator
Post Number: 5466
Get kick pods so you can put some 5.25"s or 6.5"s in there. No cutting involved.
You won't find a good 3.5" replacement speaker, really. They're all garbage at that size.
