Blaupunkt T1 NIV2 radio code?
Username: Woody2010
Hello there,
I am after the code for my mums radio and was wondering if anyone could help.
The radio is from a peugeot 206 w-reg
Blaupunkt T1 NIV2
part number 7648146392
model number BP8146Y5905753
Thanks, Alan.
Username: Hay88
Post Number: 1728
Woody2010
try code 2154
Username: Woody2010
Thanks hay88, I've got the fun hour or so wait because my mum put in the wrong code earlier but as soon as I've tried it ill let you know how I get on.
Thanks.
Username: Woody2010
hi
Do you have any idea why it is still not giving me the chance to try anotheR code? Is it possible to completely lock these radios?
Thanks, Alan
Username: Hay88
Post Number: 1763
Please note that code entry is only possible when the display says " CODE ". If the stereo is codelocked, leave it switched on for up to two hours or more and a further attempt at code entry should be possible.
so leave turned on untouched until it resets itself.
don't touch any button cause if you do the wait time will start from the begining.
if you find the radio turns itself off after 20mins.
wait till you go on a long drive and then leave radio on still
Username: Woody2010
Hello, I have left the radio for over 2 weeks now and it is being used everyday but it is still not giving me the option to try another code. I've tried disconnecting the battery but still no joy, any ideas on what I can do?
Thanks
Alan
Username: Hay88
PortsmouthUk
Post Number: 1985
disconnecting the battery will not help.
what is on the display?
it's a must be turned on and untouched.
Username: Woody2010
It says 'radio locked' on the display, I tried leaving it untouched but on for about a week, driving about an hour a day, and still no joy.
Username: Hay88
PortsmouthUk
Post Number: 1989
I have known someone have to leave it on for 11 hours before.
If not then you will have to take it into a Decoding Service to rest
Username: Regrooster
Post Number: 5248
Alan
Username: Woody2010
Posted on Wednesday, September 22, 2010 - 02:41 pm:
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
The important bit is UNDISTURBED because if it gets interrupted then the waiting time starts all over again.
This means that "an hour a day" will NOT work.
It may be better to remove it from the dashboard and connect it up to a spare battery on your workbench and leave switched on overnight.
This definitely works for most locked radios.
