Peugeot 205gti 1990 clarion
Username: N22
as i'm a new member! first of all can i say , Hello to everyone and hope all is well with you all,i would like your help with a code matter ,just bought the car but no code for the radio!!the radio is a clarion,s/n 002648,prod/n pu-9469a many thanks
norm
Username: Hay88
PortsmouthUk
Post Number: 1981
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
OR You could email restoredclassic@aol.com
as it's an old clarion to see if they can help
Mention this forum
Username: N22
many thanks for that, just having a good look and in pen is {84080395} could this be the code, if so as i have no manual how do i enter the numbers
cheers norm
Username: Hay88
PortsmouthUk
Post Number: 1982
sorry posted same twice
Username: Hay88
PortsmouthUk
Post Number: 1983
try entering the first digit by
repeatedly pressing 1, the second by repeatedly pressing 2, the third with 3, fourth with 4, then hit some obscure button to enter the code
(rather than the obvious '5' it was the 'tune up' button or something. i not 100%
i have sent you email.
i dont think {84080395} is to do with your code.
Username: Regrooster
Post Number: 5234
As this is an old 1990 CLARION , before giving up , try emailing
to see if they can offer any further advice
Mention this forum
Username: N22
great news got in contact with restored and they came up trumps!!! so got sounds now ,but cannot get any upto date stations,any ideas,medium wave is fine ,but as i have no manual so cannot fined any fm or other,i do'nt want to take it out as it is the original,so com-on guys you came good last time,lets do it again
and many thanks for your help
norm
