Renault Megane Code please??
Username: Andyo
Hello,
I was wondering if anyone could get me a code for the following:-
Model Number 22DC259/62P
Product Number FD0400390160592
RN259FY0160592
7700434424TI949
7700 434 424
As you can see, I have given all the information found on the side of the radio..
Thanks in advance.
Andy
Username: Regrooster
Post Number: 5221
try code 8 1 6 6
Username: Pecia28
hi Can you help me with this radio renault megane scenic 2001
model number 22dc259/62p
tov974
rn259f1024247134
fd0501110247134
7700434424tv974
Thank you
Username: Hay88
PortsmouthUk
Post Number: 1950
Pecia28
your code 4015 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Andyo
Many thanks Reg Rooster!!
Finally some music in my wifes car, its been months! Excellent work!
Username: Pecia28
To hay88 Thank you
Username: Amsternl
Hi, can anyone help with a code for Renault Megane 2006
Username: Hay88
PortsmouthUk
Post Number: 1979
Amsternl
your code 0141 you must hold at end to store code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Amsternl
Thank you hay 88
