Ford Modeo radio requires code
Username: Key4174
I have just received my car back from having some work done and the radio is asking for the code. The dealer want £35 to sort for me!!!
Its a Ford Mondeo 03 and the radio is a 6006 cd rds e-o-n - can anyone help???
Username: Hay88
PortsmouthUk
Post Number: 1889
Key4174
post your serial number here something like m123456
can be found on the radio.
try this first simply turn on the radio, hold down button 6 and press 2.
The serial may be shown allowing you to easily get your ford radio code
Username: Key4174
Thanks hay88, I gave this a try but it returned the message 'NO SER' - so I guess I'll need to try and remove the radio.
Anyone know where I can get the tools to do this?
Username: Hay88
PortsmouthUk
Post Number: 1896
Apply outward pressure on the special tool while pulling the audio unit away from the instrument panel.
Remove the audio unit.
You can make a tool good enough to do the job by bending up a couple of pieces of coat hanger.
Username: Key4174
Thanks, I seem to be getting somewhere.
Serial number M020370
Thanks again for your help!
Username: Regrooster
Post Number: 5210
Code = 2 1 9 8
Username: Key4174
Sorry for the late reply but I've been away for a few days, code worked; thanks for your help.
