hi i cant find my manufacture book so dont have the code for my radio but i took it out and got the details which are MN-22DC27B/62B PN-FD0302200200199 RN278F20200199 8200057681TD591 T0591
Whytelj D591 = 1428 you must hold at end to store code. please check > 8200057681TD591 and T0591 < Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Whytelj please check 8200057681TD591 number for me. The Code number is entered by using the remote steering controls, and not through the buttons on the fascia. you can sen me a photo of label if you like.
Hi i also need a codefor my vauxhall stereo, after disconnecting the battery. The numbers on the top are: gm0d3092404029 497316088 13289932 034451 Dont know what numbers you require so i put them all down! Thanks alot
hi i cant upload the picture it says its too big!!! just took a picture and these are the details 820057681TD591 TOD591 RN278f20200199 model number 22DC278/62B product number FD0302200200199
Whytelj T0D591 = 1428 so if still not working and you have entered like i said by using the remote steering controls, and not through the buttons on the fascia.
take to you local Decoding Service to see if they can help you.
Can anyone help or shall i take it to vauxhall? wifes driving me mad mithering me to fix it!!
