Code for renault megane scenic
Username: Karene28
hiya, ive had my battery changed and the radio is asking for a code. i bought car second hand so dont have a user manual but the serial numbers are as follows:
model - 22dc278/62r
product - fd0202400022760
rn n.o - rn278f20022760
barcode - 820050474tg743.
can anyone help or point me in the right direction??
thanks
karen
x
Username: Hay88
PortsmouthUk
Post Number: 1903
Karene28
your code 5807 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
