Security code Mitsubishi Mirage
Username: Banky_kmit
I have some problem. I brought second hand mitsumishi mirage car.I changed battery and My radio car clarion can't use because I don't have security code for encoding the radio. Can you help me?
Clarion Pm-2308u-A
serial no. L3-0071675
Thank you so much
Username: Hay88
PortsmouthUk
Post Number: 1976
Banky_kmit
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
