Username: Key4174 Post Number: 1 Registered: Sep-10
Tuesday, September 14, 2010 - 21:44 GMT I have just received my car back from having some work done and the radio is asking for the code. The dealer want £35 to sort for me!!! Its a Ford Mondeo 03 and the radio is a 6006 cd rds e-o-n - can anyone help???
Username: Hay88 PortsmouthUk
Post Number: 1889 Registered: Mar-10
Tuesday, September 14, 2010 - 21:51 GMT Key4174 post your serial number here something like m123456 can be found on the radio. try this first simply turn on the radio, hold down button 6 and press 2. The serial may be shown allowing you to easily get your ford radio code
Username: Key4174 Post Number: 2 Registered: Sep-10
Wednesday, September 15, 2010 - 11:20 GMT Thanks hay88, I gave this a try but it returned the message 'NO SER' - so I guess I'll need to try and remove the radio. Anyone know where I can get the tools to do this?
Post Number: 1896 Registered: Mar-10
Wednesday, September 15, 2010 - 13:15 GMT Apply outward pressure on the special tool while pulling the audio unit away from the instrument panel. Remove the audio unit. You can make a tool good enough to do the job by bending up a couple of pieces of coat hanger.
Username: Key4174 Post Number: 3 Registered: Sep-10
Wednesday, September 15, 2010 - 15:10 GMT Thanks, I seem to be getting somewhere. Serial number M020370 Thanks again for your help!
Username: Regrooster Post Number: 5210 Registered: Aug-08
Wednesday, September 15, 2010 - 15:29 GMT Code = 2 1 9 8
Username: Key4174 Post Number: 4 Registered: Sep-10
Saturday, September 18, 2010 - 12:28 GMT Sorry for the late reply but I've been away for a few days, code worked; thanks for your help.
