Amp Advice for SWR-1221D
Username: Thedocker
Dugald, MB Canada
hey guys i just recently got a 12" type r (SWR-1221D) and was wondering if anyone had any advice on an amp to get with this? its a dual 2 ohm sub with about 300 rms. price isnt really an issue. any input would be fantastic, thanks.
Username: Wandaddy
Naha, Okinawa Japan
Post Number: 28
Well, you are only going to be able to get a 1 or 4-ohm load from that sub. If you had 2 of them you could wire them for a 2-ohm load though. Here are a few of suggestions, but I'm not sure if these amps are 1-ohm stable:
Alpine MRP-M500 - 300W RMS @ 4-ohms
Eclipse XA1200 - 350W RMS @ 4-ohms
JL Audio J2 500.1 - 340W RMS @ 4-ohms
Rockford Fosgate PRIME R500-1 - 320W RMS @ 4-ohms
They all make decent power at 4-ohms(enough to push your SWR-1221D) , and are under $200 on most websites.
Username: Thedocker
Okay, thanks alot i appreciate it, hat helped me out a bit. I was looking at the m500 and thought it seemed to be good enough for the sub, and i thought i heard from someone that the alpine MRP-m500 was only 2 and 8 ohm stable but i guess i heard wrong? Thanks
Username: Thedocker
Username: Insearchofbass
2 hifonics 2607s, 2dcSounds12xls SPL\idmax12SQ
Post Number: 15292
* Per channel into 4 ohms: 300W x 1 (0.08% THD)
* Per channel into 2 ohms: 500W x 1
Post Number: 15293
it would be good in case you get a second sub too
Username: Thedocker
Are you sure my dual 2 ohm could be wired to the alpine MRP-M500 thought? at 4 ohms?
Username: Wandaddy
Naha, Okinawa Japan
Post Number: 30
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Check out this link and it will answer your question.
