Many thanks for the info regarding how to enter car code. However after all that the code did not work. The radio serial number is 22DC459. Can you help with the code?
Please quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
These are all the numbers we can find on the radio RN458FW209849 7700 426 483 B392 Philips 22DC459/62E 9022 214 59622 FD 0898 27 209848 Hope you can help
