Renault laguna radio code
Username: Lagunaman
Hello,
please could you help me as to getting my radio code for my laguna.
battery had to be disconnected and now i cant put in code as i do not have it.
numbers i have from radio are as follows:
22dc279/162z
t0z748
rn279f10035349
fd0101070035349
8200002607t248
8200 002607
that is all the info on radio.
please help me thank you.
Alan
Username: Regrooster
Post Number: 5190
Try code 0 2 5 3
Username: Lagunaman
thanks very much reg rooster. my sounds are back up and running.
many thanks and you are a credit to this forum.
Username: Snowrider71
Had to change the clutch and the baterie was switched off at the garage now is asking for the code can anyone help me out with the code please, it's a W reg year 2000 i havent got the tools to get the stereo out help please. thanks in advance
Username: Hay88
Post Number: 1875
Snowrider71
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
thank you Hay88
i've just taken it out it worked thanks
the Model No :22DC279/62
TOJ 279
RN279FY0058836
PROD N: FD0100190058836
and then the numbers under the bar code is
7700433948TJ279
and
7700433948
that's all the number on the sticker with the bar code
any good to get the code?
thanks
Post Number: 5203
re Snowrider71
RENAULT
Try code 1 0 6 1
can anyone help me out with the code?
i've added all the radio details
thanks
Post Number: 5204
just answered !
These requests are answered by volunteers so don`t be so impatient!
If you were in such a rush , then you should have used an OnLine Decode Service who will reply straightaway....for a fee !
Ok, cool thank you Reg Rooster
I'll have a go at it now, do i need to press any touch in particular after entering the code?
and thank you again
just tried by entering the numbers 1061 didn't work, am I doing something wrong?
Username: Hay88
PortsmouthUk
Post Number: 1880
Snowrider71
your code 7579 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Post Number: 7
Hi Hay88,
I've just done it as you said and using that code it worked straight away
thank you ever so much
you're a star
