Hello, please could you help me as to getting my radio code for my laguna. battery had to be disconnected and now i cant put in code as i do not have it. numbers i have from radio are as follows: 22dc279/162z t0z748 rn279f10035349 fd0101070035349 8200002607t248 8200 002607 that is all the info on radio.
Had to change the clutch and the baterie was switched off at the garage now is asking for the code can anyone help me out with the code please, it's a W reg year 2000 i havent got the tools to get the stereo out help please. thanks in advance
Snowrider71 you need to remove the radio. they are too small holes each side of the radio use an old metal coat hanger 4 darts or very small screwdriver or long nails. put into holes about 4-5cms and push outwards sideways and carefully pull radio forward. you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
thank you Hay88 i've just taken it out it worked thanks the Model No :22DC279/62 TOJ 279 RN279FY0058836 PROD N: FD0100190058836 and then the numbers under the bar code is 7700433948TJ279 and 7700433948 that's all the number on the sticker with the bar code any good to get the code? thanks
Snowrider71 your code 7579 you must hold at end to store code. Code Entry as Follows: Switch Radio On - Display Shows " CODE " Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
