New member Username: Agatto2NFUS Post Number: 1 Registered: Sep-10 | I have no Idea if this is the right place to post this. I have an older base 5 bose system. The base seems to be ok after I got the cd lens to stop sticking. The problem I am having is with the sub-woofer system. The numbers are A5Pe0Du123971 and C9646 When I power on nothing happens. I happened to be able to prey the case off (WTGF Bose) to get a look on the inside Every thing looks pretty good good as far as the circuit board goes , fuse is good and all the wires look connected. So I am looking for a trouble shooting guide - Does anybody have one or know where I can get one. Or maybe someone can get me started on the transformer trouble shooting to start. tony |
Gold Member Username: ExerciseguyFort Hamilton, NY United States Post Number: 3356 Registered: Oct-04 | May I suggest...http://www.bose.com/controller?event=view_static_page_event&url=/customer_servic e/owners/faq/product_faq5.jsp |
Silver Member Username: EdisonGlendale, CA US Post Number: 944 Registered: Dec-03 | Don't open the section with an amp in it !!! It can discharge electric shock even with the power chord off. Take it into a shop, or better yet, if you can afford it, get a real Hifi system - Bose is not Hifi. |
New member Username: Agatto2NFUS Post Number: 2 Registered: Sep-10 | Thanks Christopher Molloy - But useless as they have no trouble shooting skematics there James those shockers are called capacitors. I will be super careful thanks for the heads up. Now does anybody have some DIY Repair Info on these? Where is Mark Burgess from this post? He has the info I need ? https://www.ecoustics.com/cgi-bin/bbs/discus.pl Tony |
Platinum Member Username: NuckPost Number: 15411 Registered: Dec-04 | Tony, only Mark or the great pumpkin can save you now. If you find Mark, please give him my regards. Jamie |
New member Username: Agatto2NFUS Post Number: 3 Registered: Sep-10 | Hi Nuck - I know I was hoping he would see the batsign and hit me up, as for the great pumpkin its not his time yet. His PM is off which I can well understand. Anyone? anyone? Burgess? Has anyone else received the schematics for this system? My model is1059-b and seriel is00a 00016. The system is not actually mine but an older friend that has fond memories and wants to keep the system working. Tony |
Gold Member Username: ExerciseguyFort Hamilton, NY United States Post Number: 3358 Registered: Oct-04 | Is door stop two words or one? |
Gold Member Username: GavdawgAlbany, New York Post Number: 1585 Registered: Nov-06 | Those acoustimass cubes (if caulked) could also be used as a coffee mug. |
New member Username: Agatto2NFUS Post Number: 4 Registered: Sep-10 | Come on ---- Does nobody have the schematics for these? efffffffff Does anybody have any KungFu for these? |
