What does everyone think about this amp: http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=157&idproduct= 527 powering 2 12" Sundown SAs?
Rated Power @ 2 ohm RMS: 500 Watts x 1 Rated Power @ 1 ohm RMS: 1000 Watts x 1
Bridged Power @ 2 ohms RMS: 4000 Watts x 1 *
Minimum THD at Rated Power: <0.1%
Frequency Response: 10Hz - 500Hz S/N Ratio: >100 db Damping Factor: > 230 @ 100Hz Dimensions: 9.25" x 2.5" x 16" *With two iA9-HC bridged together.
FEATURES:
Input Voltage: 200mV - 9 Volts.
12-24dB Crossover Circuitry.RCA Preamp Output.Bass Focus Control.Adjustable Subsonic Filters.Adjustable Phase Control.Soft Start Mute & Delay.Power & Diagnostic LED Indicators.Computer Optimized Heatsink Design.2 Channel Models: 4 ohm Bridgeable, Tri-mode Capable.Class D Models: 2-ohm and 1-ohm Stable.Class D twin amp bridgeable/double output power in to next highest impedance.Master/Slave configurable.Dashboard bass remote control included with all models.
some of those cadence amps i noticed have overrated specs since if u check the fuse rating it just doent seem possible to be doing the power they claim ...
Roving, the one I was looking at was Rated Power @ 1 ohm RMS: 2000 Watts x 1. But anyway, the deal fell through. I am getting 2 12" Sundown SAs and wanted to give them a little more power. Anyway, thanks guys.
