What does it mean when you can't bias a tube?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 4219
One tube out the 8 EL84's I got today that I can't bias above 200mv (the recommended bias in 250 for Stingray). I've moved the tube to other sockets, and it's always the same. If I turn the trim all the way to max, it'll only bias at 200 mv max. Does this mean there's something wrong with the tube?
Username: Nuck
Post Number: 15355
I would hazard a 'yes'.
Username: Dmitchell
Post Number: 4220
Me too.
Username: Stu_pitt
Irvington, New York USA
Post Number: 3968
I've never biased a tube, but if that's the only one that won't bias (in any spot) and the rest will, I think its safe to say its the tube.
Do other tubes bias in that spot?
Username: Dmitchell
Post Number: 4221
Yup, they all bias exactly where they should be.
Username: Stu_pitt
Post Number: 3969
Its kind of like changing your spark plugs, and one cylinder won't fire. You change where the cylinder where that spark plug is, and that cylinder doesn't fire.
I'd be willing to bet it's the spark plug, but that's just me.
Username: Dmitchell
Post Number: 4222
If you move it around, and the problem follows where you move it to, odds are its the tube (or sparkplug). I've already contacted The Tube Store to get a replacement.
Username: Dmitchell
Post Number: 4226
The tube shop expressed me out a replacement tube the next day at no cost. Can't say enough good things about these guys.
http://thetubestore.com/
Username: Dmitchell
Post Number: 4250
Man, my troubles never end. Over the last week I've noticed intermittent distortion in the left channel of my Stingray. I swapped around all the tubes, switched the speakers and even changed speaker cables. The problem is always in the left channel. Spoke to a repair guy here in Ottawa that was recommended on CAM, so the amp is going to him for a look. Hopefully it doesn't cost me too much fix. I guess the good news is they repair says tube amps are "easy to repair".
Username: Magfan
Post Number: 1579
Please post back when the verdict is in.
I'm curious to know if the bias adj prob and the distortion are related.
Username: Dmitchell
Post Number: 4263
The amp is at the repair shop as of yesterday. The tech hasn't had a chance to take a look at it yet. Looks like I'll be without it for the weekend... bummer.
Username: Soundgame
Pickering, Ontario Canada
Post Number: 1184
Oh, that's crap Dave, sorry to hear about the troubles. You'll get 'er back - just hope it's a cheap fix. Hopefully, he'll give it a bit of a tune up at the same time, turn here, squeeze there.
