Hi just bought 97 Renault Laguna with a couple of electrical snags, sorted most out just need radio code now. Philips Radio Sat 600, number on side is RN479FW9056594. Code Gravage 9056594(bar code), Model Number 22 DC479/62. Other numbers -7700 426 484 W826, FD0898 25 9056594, 9022 214 79629. Any help much appreciated, Thanks in advance.
Hi, Code given for Philips Radio Sat 600 in my earlier post does not work, on entering and holding button display just goes back to CODE. Are there any other possible codes? Thanks.
Seawarrior please check Other numbers -7700 426 484 W826 = 3187 IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
Hi, Sorry to be such a nuisance but I have double checked all serial numbers that I gave and they are correct. Radio still not accepting code, have entered it as instructed but last digit continues to flash and when () button is pressed and held display goes back to CODE. any ideas? Thanks
