Need code for Renault Megane II
Username: Vrabec
Hello, I lost my code for Renault megane II 2003,can anybody help?
Model: 22DC277/62
T0Z626
RN277F20040183
FD0002440040183
8200256141TZ626
Many thanks!!!
Username: Hay88
Post Number: 1820
Vrabec
your code 0347 you must hold at end to store code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Vrabec
It works!! Thank you very much!!! You're just great!!!
