3 Pre Outs on HU?
Username: Ddegagne
Post Number: 11
I had a pioneer HU with one pre out which I had connected to my 4 channel amp then I wired my speakers and sub from there. It worked fine.
I just bought an new pioneer 4200 ub and it has 3 pre outs, one for front, rear and sub. I assume this means I run 3 sets of rca cables to my amp rather than just using one to deliver the signal.
Might sound dumb, but is this correct?
Don
Username: Joe1234
Post Number: 23
You can still connect your new HU the same way it was using any pre outs but the one for the subs. I find the crossover on most HUs rather limited anyways, also once setup you don't really need to change the gain for the subs all the time.
Username: Ddegagne
Post Number: 12
So Joe are you saying I should use the pre out for the sub and one for my speakers or should I just use one pre out for all? What is the best way to connect?
Don
Username: Joe1234
Post Number: 24
Not that you should but its the simplest way. For a fully active 4 way setup featured in top HUs then it would be worth it to run cables all around.
