New member Username: Sfeher
Post Number: 1 Registered: Sep-10
Posted on Hi, This is what I see on the side of radio: RNRD6950061120 RENRDW240-00 FD01 0514 0061120 Under the barcode: 8200483757T L796-SECURITY Thank you in advance! |
Gold Member Username: Hay88
Post Number: 1773 Registered: Mar-10
Posted on Sfeher your code 2519 |
Post Number: 2 Registered: Sep-10
Posted on Thanks a lot. I will have a try tomorrow. |
Post Number: 3 Registered: Sep-10
Posted on Works fine! Thanks again! |
