Code
Username: Abhi1265
hi iam abhishek from india i lost my fiat punto bosch radio code now it not working asking 4 digit code can u give send the code my radio is bosch)fiat323 mp3 myo8 emotion(7648299316) ei(034502)fiat number(7354859450)plz send me the code soon my email(abhishek.menon14@gmail.com)plzz help me serial number(815cm829993680790)
Username: Hay88
Post Number: 1787
Abhi1265
i have sent you an email
Username: Hkabj461
Hi,
I bought a honda Accord 2003 model. I lost the code for the car radio. Pls can you help me to retrieve it.
The serial N0 is:12140511.
Will be waiting. Thank you for ur anticipated assistance,
Username: Regrooster
Post Number: 5146
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PANASONIC
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with
7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Stephenjholmes
Hi
I am hoping someone can help.
I need a code for a Rover MG Stereo CD5404 MP3X
The info on the label is as follows
XQE000940PMA
VDCD3242000945
A2C53099318
CG000511000945
I hope this is enough info to find me a code.
If not I would apreciate any info that I can get about where I might be able to get it sent to for decoding.
Thanks
Steve
Username: Danechem
Hi,
Please could you tell me the code for my blaupunkt radio, car 2003. Took it out of my '04 Meriva to try to replace it with CD player which doesnt fit and now it is saying safe on the display!
The numbers on the top of the unit are 12127011 and 7649200325.
Thanks alot
Username: Danechem
Hi, Further to my last post the serial number on the unit is gm020347399504. Thanks again.
Post Number: 5147
dan
Username: Danechem
Posted on Tuesday, September 07, 2010 - 02:47 pm:
Hi,
Thanks alot
dan
Username: Danechem
Posted on Tuesday, September 07, 2010 - 03:07 pm:
Try code 9 5 0 7
Post Number: 5148
Steve
Posted on Tuesday, September 07, 2010 - 01:40 pm:
Hi
XQE000940PMA
VDCD3242000945
A2C53099318
CG000511000945
Sorry...Main Dealer or Radio Decoding Service only for this code
I prefer not to recommend any particular service.
The best decoder is a local car radio store who will perform the decoding while you wait.
Note : Please do NOT keep posting the SAME request in different threads.
It is not necessary as ONCE is quite enough.
Otherwise try Google or Ebay
Username: Danechem
Cheers reg, i'll try it tomorrow in the daylight!
Username: Danechem
HI reg,
Went to put the code you kindly supplied in my tape player but i cannot get it to do anything other than display 'safe'. I've pressed all the buttons but cannot get it to do anything, do you know what i need to do? Also there are only 5 numbers on the unit but the code you gave is 9507?
Thanks again
Post Number: 5153
dan
Username: Danechem
Posted on Wednesday, September 08, 2010 - 12:46 pm:
HI reg,
Try leaving it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itsel
This could take several hours
Five digit codes are only normally used in radios in the USA
The rest of the world use four digit codes , especially in the Model Number quoted 7649200325.
