'X' Plate Renault Meganne Radio Code required
Username: Stevew177
Can anyone help me to retrieve the radio code for my Meganne? Thanks
Username: Hay88
Post Number: 1755
Stevew177
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
hi post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
Username: Stevew177
I have the following numbers:
7700434423TS807
7700 434 423
RN279FY0015344
TOS807
Are any of these useful to you?
Thanks
Username: Hay88
Post Number: 1756
Stevew177
your code 7156 you must hold at end to store code
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Stevew177
That worked perfectly.
Many thanks for your help.
Steve
