Code for Blaupunt cdc 2 changer
Username: Dontheeagle
Hi guys,
I have a radio on my vauxhall astra, i managed to get the radio code, but it's still asking for a CD changer code
My the code is for the cd changer: GMCDC2W0749603
S/N: 90569379
Thx in advance
Username: Hay88
Post Number: 1753
Dontheeagle
GMCDC2W0749603 if the part number is 7 607 775 320
try code 2142
S/N: 90569379 ? < what is that serial from please.
The code number for the stereo must be entered before the code number for the CD Changer can be entered, although they are both entered via the head unit by using different buttons
Code Entry as Follows:
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " O " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " O " Until Unit Beeps
