Looking for Help on Viewsat Ultra
Username: Rvm
Post Number: 90
I've not used the set for a long time after the last N3 blackout guess 2009. The box is still with me..Is there a way to fix it back again...with new files, if they are available or just Chuck the box out and look out for a reliable replacement. Any help is appreciated.
Nalin / Plymouth any one listening and ready to help....
Username: Lroy
Post Number: 573
IN ORDER TO GET THE ULTRA GOING AGAIN, YOU WILL NEED TO GET A WEATHER FORECASTER, INTERNET CONNECTION AND NEW FILES.
Check the links below for more info....
http://www.ftacp.com/forums/forumdisplay.php?65-Weather-Forcaster
http://www.ftacp.com/forums/showthread.php?2388-All-receivers-708
Username: Rvm
Post Number: 91
Thanks, I'll give it a try this weekend? Where can I get weather forecaster (in Toronto area, Canada).
Appreciate your help.
Username: Nydas
Post Number: 19552
RVM: I think you can only do a mail order
