Bronze Member Username: XyourbabexMississagua, Ontario Canada Post Number: 36 Registered: Jan-10 | I am planning to buy an jadoo tv. Can you please tell me if i should buy it. Not a maybe reply. Simply yes or no with a solid reason. If no then can you please recommend me some other ways to watch all the channels on TV! Thanks. |
Bronze Member Username: XyourbabexMississagua, Ontario Canada Post Number: 38 Registered: Jan-10 | If sada cant reply then other people can too. Who is expert on going opinions and answers! |
Gold Member Username: Saqeeb9000Post Number: 7241 Registered: Oct-07 | sorry i was busy last week....didn't even came to this site.. katie i can say yes and no lol... i can say yes cause its working now... can say no cause not sure about tomorrow.. but i think since it runs on interent ... they will always find servers and stuff.. so it will work... so its all about gambling .. .. but u can go for it.. buy the hd one pic quality is ok... the sd one pic quality is bad.. channels are working..as i tested out at freinds place... |
Bronze Member Username: XyourbabexMississagua, Ontario Canada Post Number: 45 Registered: Jan-10 | so how much is the jadoo tv hd? |
Platinum Member Username: NydasPost Number: 19479 Registered: Jun-06 | https://jadootv.com/shop.php?buy=yes |
Bronze Member Username: XyourbabexMississagua, Ontario Canada Post Number: 46 Registered: Jan-10 | is there any ways to watch free channels on tv.. |
Bronze Member Username: Black_jackPost Number: 23 Registered: Jul-10 | YES, Open this Link and see what free channels you can watch. |
Gold Member Username: LomnaSac, Calif U.S.A Post Number: 1312 Registered: Dec-07 | Katie, jadootv, the name sounds like it is owned by an indopak guys.if it is true, katie I'm sure it will stay in the market for while compare with others.Secondly when you ask sada "if not jadootv what other option " sada was was right, you can trust these boxes. There is no better box today. All are equally good and bad. |
Platinum Member Username: NydasPost Number: 19485 Registered: Jun-06 | Devin: The list of dealers is there at the URL I gave above. If you read the list, you will get a very good idea of ownership |
Silver Member Username: Dj_princePost Number: 154 Registered: Feb-08 | hi guys i need urgnet help . i have two option either i can get dreambox DM100 or DM500. which one works good with private server? if i get DM100, is it good enough because i am getting it for very good price, Thanks alot |
Gold Member Username: Saqeeb9000Post Number: 7245 Registered: Oct-07 | DJ don't get dreambox. get neosat ipro 2000.. all private server uses neosat ipro 2000..too here is why u don't get dreambox.. first .. doesn't have usb port.. tha'ts a big lack..u don't know how much time i spent .. loading a file lol.. secound dreambox remote sucks.. i have to open a front sceen now its better... if u look at neosat ipro 2000 it cost same.. i am not sure about 500 but if u must wanna buy between dm 100 and dm 500 i will go for 500 |
Silver Member Username: Dj_princePost Number: 162 Registered: Feb-08 | hi sada can you please tell me if Willow TV availiable on 118.8? on NFPS if yes what channel? Thanks |
Gold Member Username: Saqeeb9000Post Number: 7264 Registered: Oct-07 | 18.8 Anik F3 Willow Cricket Channel Number 582 installation tp edit add tp 12019 20000 vertical then save then go back go to tp scan choose manual then chose 12019 V and scan Enjoy...................... |
Silver Member Username: Waqarkhan1971Post Number: 128 Registered: Mar-09 | Hi Sada, I wonder if u can help I got access code from iksprivateserver, but according to inst. provided on their website for CAPTIVEWORKS 700,seems nothing working . do u have any idea with this new iks system? |
Silver Member Username: XtrawestBC Canada Post Number: 367 Registered: Nov-05 | Waqar Khan, I set up someone's CaptiveWorks 800S with iksps w/o any issue few days back. Make sure ur following the instructions correctly mentioned on their website 'n also try the codes they send u with some other receiver to make sure if they work. |
Silver Member Username: Waqarkhan1971Post Number: 129 Registered: Mar-09 | I got code and sent them back to recheck and OK I do see free channels but when I try to SAVE the CONFIG file , it does save but nothing comes up I spent several hours going back and forth on instructions and followed Just frustated |
Silver Member Username: Dj_princePost Number: 163 Registered: Feb-08 | thx sada really appreciated |
Silver Member Username: The_devilPost Number: 337 Registered: Aug-07 | Hey sada can you provide some links for the Pak vs Eng t20 match plsssss |
Bronze Member Username: Crispy_fryPost Number: 25 Registered: Aug-09 | ?? http://www.freedocast.com/Live247 |
Gold Member Username: Saqeeb9000Post Number: 7266 Registered: Oct-07 | try justin.tv or streamsdirect |
Silver Member Username: Waqarkhan1971Post Number: 130 Registered: Mar-09 | thanks Xtra West and Sada, I got my cappworks 700 up and running smothly, seems file saving problem. |
Platinum Member Username: NydasPost Number: 19566 Registered: Jun-06 | Waqar Khan: Would you please post the exact procedure you did? Also please post info on channels available on CW700 |
Silver Member Username: Waqarkhan1971Post Number: 131 Registered: Mar-09 | Yes Nydas, After I got Code# from them, Here's what u do Load any bin to CPW Rescan Satellites Enable card share F1555 Enable Patch F1 000 Autroll off Make sure you should see any of the FREE channels and have it on the screen Connect serial NULL cable from PC to Computer Then unzip files Run ULTRAEDIT program (in the zip files) Load file rss.config make changes as per their instructions, add CODE they have provided and save the file to your computer wait at least 5 min and DO hard reboot from the back Turn it on and you go and WATCH TV , Enjoy I hope this would be helpful |
Platinum Member Username: NydasPost Number: 19575 Registered: Jun-06 | Waqar Khan: Are you getting the Indo-Pakistani channels? Is there any freezing? |
Silver Member Username: Waqarkhan1971Post Number: 132 Registered: Mar-09 | Yes Indo/Pak are all ON, no freezing at all |
