Which works best
Username: Itatum
Post Number: 61
i just wondering, my HU has a blue sub RCA cable and two sets of other RCAs that all can go to the amp. Right now i have the blue sub cable going to my amp and i think it sounds good hits pretty hard, but i can't use the controls on the amp. so i guess my long winded question is let the HU control things or let the amp. Thanks I.T.
Username: Illuminator
Post Number: 5408
You can use the controls on the amp still. In fact, you probably are, but it might not be as noticeable is all.
I personally prefer using the filters etc. on the head unit because they can be adjusted more conveniently, and the difference in quality of filtering is negligible.
Username: Itatum
Post Number: 62
thanks for the info
