New member Username: Class08820Post Number: 9 Registered: Jan-10 | Guys I just need to ask you about recently Dish moved hindi channel to diffrent satelite I have two dish pointed at 119,110 and 61.5 so I am not getting couple of Hindi channels Does any body have channel guide which Hindi channel coming on which satelite Thanks in advance |
Gold Member Username: Mrskullz1New York Post Number: 1787 Registered: Feb-07 | 118.7 Anik F3 All of the international channels that you are looking for have been moved to that satellite. If you want a guide of all the channels, go to lyngsat.com and choose 118. |
Bronze Member Username: Black_jackPost Number: 38 Registered: Jul-10 | Class08820 Here is a list of the Hindi channels that are listed on Dish Network. Which ones are you looking for? |
New member Username: Class08820Post Number: 10 Registered: Jan-10 | I have all channels listed on list means Hindi Mega Pack |
Bronze Member Username: Maharaja6000SurreyCanada Post Number: 71 Registered: Nov-06 | is there any hindi channel working ,if we move the dish? |
New member Username: ShehbaztPost Number: 6 Registered: Feb-08 | no hindi/ pak channels are working. |
Silver Member Username: Trendsetter369Post Number: 181 Registered: Dec-07 | Are these Hindi channels working on Limesat |
Platinum Member Username: NydasPost Number: 19508 Registered: Jun-06 | Click here for IKS status |
Bronze Member Username: Class08820Post Number: 11 Registered: Jan-10 | Guys I remember one web site that will tell you if you need to point dish about dish Azimuth and Skew point one more is it hard to point satellite to 118? I didn't find list which satellite cover which channels? Thanks in advance |
Platinum Member Username: PlymouthCanada Post Number: 14495 Registered: Jan-08 | class08820 |
Platinum Member Username: NydasPost Number: 19511 Registered: Jun-06 | It is NOT hard to point to 118.7W. Just point to 119, make sure the signal is lood and clear and you are there. The more important thing is the size of Dish, which has to be 30" or better still 33", and the LNB has to be a special Circular LNB with a low LNB frequency of 10750 or 10600 |
