Becker radio code for lancia
Username: Youplaboum
Hi,
I would need a code for a lancia with becker radio :
typ: IDIS
Model n°: BE 2580
serial n°: 15062618
Hope this info can help.
Many thanks in advance.
Regards,
Youplaboum
Username: Hay88
Post Number: 1663
Youplaboum
your becker part code 0469 but i can't help with the siemens part.
BECKER + SIEMENS
Thanks, hay88.
Here is some more info related to SIEMENS:
MLFB:5WK 78214
Serial n°: LA2140087927/03
Would it help?
many thanks for your feedback.
Best regards,
Youpla
Username: Regrooster
Post Number: 4991
Sorry...Main Dealer or Radio Decoding Service only for the Siemens code
you mean...for the BECKER code.
OK, no big deal. Thanks anyway for your help.
Best regards,
Youpla
Post Number: 4995
SIEMENS Code ..Enter first...but this is not available here
then enter BECKER CODE = 5 1 4 6
So really the whole job to make it work has to be done at the Main Dealer or a Radio Decoding Service
