Need Help Too!!!
Username: Paulie_walnuts
Radio Code for a Renault Megane Scenic.
T Reg
VF1JA020c18983210
Dont have any other details as Radio is in panel on dash so can't see any other numbers etc.
Can someone please help?!
Cheers
If I need to provide other details can someone tell me where to find these?
Thanks,
Username: Hay88
Post Number: 1668
Paulie_walnuts
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time.
then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
ok used darts!
these are all the numbers as listed
philips 22dc461/62L
FD0998514134047
Model no. 22dc461/62L
thanks a lot mate
Username: Hay88
Post Number: 1669
Paulie_walnuts
need the one from below the main fat barcode it looks something like
7700xxxxxxxt123 8200xxxxxxxtt123
ok the only other number is:
7700433072P415
Please let that be right!
Username: Hay88
Post Number: 1670
Paulie_walnuts
your code 0538 you must hold at end to store code
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
thanks so much!
Legends.
