Renault Laguna 2001 3.0 V6 RADIO CODE NEEDED
Username: Pavelchehoff
Hi guys.
Looking for radio code for Renault Laguna MKII 2001 3.0l V6.
Model No.: 22DC279/62E
TOG618
RN279F10003113
PROD No.: FD0101020003113
8200063200TG618
8200063200
Thanks a lot.
Username: Hay88
Post Number: 1733
Pavelchehoff
your code 6188 you must hold at end to store code
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
The Display Shows " 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
