I am planning my next system for my car and the problem i face now is my mounting depth. In my car the most i can go is 2.75 and thats pushing it. So i am open to component speaker suggestions. The ideal choice i am looking for is something that performs the most beyond its price range or simply the best component set under 2.75 in mount depth. I listen to mostly hip hop music, but i like a system that sounds good all round. i like good midbass but i favor great highs, not harsh but a clear and to stand out i guess.
the speakers i wanted to get the most were the ID cxs64 or 62 v.2 but they are too deep and will not ft without major modification.
ones im considering: 1. dls up6i (most interested) 2. ID ctx65cs 3. cdt's (es-620) (if they fit) cant find mount depths 4. focal kr
i am open to any other suggestions you may feel is better. im hoping to narrow down my list because many of these i am unable to here due to my location.
by the way, these will be powered by a jl 300/2 or jl a4300
Can you add some mdf to the door to mount the speaker onto? That would add more depth and also give you a better mounting surface. Be sure to isolate the driver as much as possible. Sound deadner behind and around the driver.
