Denon AVR-2802 Reciever soundless.
Username: Pojo
My Denon AVR-2802 reciever gave it up after a continues high
power operation. The unit is mounted completely air free,so ventilation could't have been the problem.However I turned off the power,let it cooled down and turned it back on. Only the standby led keeps flashing. The input mode indicators does not light on,and no sound any more. I have done every step the trouble shooting guide says but nothing works.Any sort of help would be greatly appreciated.
Thanks!
Username: Nuck
Post Number: 15357
Was one step unplugging the unit overnight?
Username: Vm8444
TorontoCanada
Post Number: 277
hi there,
are you using a decent power bar not crappy one?
hey I ran into one similiar anyways have reciever checked out for an estimate
sounds like somethings faulty.
www.theaudioguy.ca
