I need help connecting my receiver
Username: Carguy012
I just recently bought a new house, i got it all "pre wired". So I have two plates at the back for the back speakers. Another two at the front for the front speakers. easy right?But im looking for another plate to connect my receiver so those speakers will receive some sounds. All I can find is a plate with a coaxial, and another one with 2RGB & 2Cal5! Did I get screwed here? Or am i missing something? can you guys help? im really new to this...thanks!
Username: Sperg1
I have the ht-391 trying to hook it up to an phillips hd flat screen and i am geting no sound what might i be doing wrong? plz help
Username: Vm8444
TorontoCanada
Post Number: 276
Spergon
why are you hijacking Richie's thread?
Dichie sounds like you should hire a local installer from the net,
anyways forget about a plate ok?
as long as the rear speakers and the front come and end up to a place coming out of the wall behind equipment rack..
i.e.
reciever your fine....
www.theaudioguy.ca
