Archive through July 16, 2010
Username: Dkkoala
Grundig
No: 90 462 562
Type: CAR 200 (D)
GM0200V3807940
Username: Regrooster
Post Number: 4312
eckyboy
Username: Eckyboy
Posted on Tuesday, June 29, 2010 - 02:12 pm:
Volvo HU-605
VO2080 Y7219367A
Other numbers 30887084 and 0292(maybe the code)
big thanks if you can help
Sorry....Main VOLVO Dealer or a Radio Decoding Service only for this code
Username: Dkkoala
It's for an Opel Corsa B from 1999, but the previous owner did not have the car and radio pass.
Username: Hay88
Post Number: 1256
Dkkoala
try code 5467
Username: Xavibock
hi, can you help me with my code for my radio?
my codes are:
Model No: 22DC279/62F
Prod. No: FD1004220201751
Barcode: 8200029541TT953
14 Digit serial: RN279F40201751
thankz a lot.
.::xavi::.
Username: Hay88
Post Number: 1258
Xavibock
your code 6046
Username: Kangiska
Good morning. I hope you can help me with the code for my BMW Z3. The cd/radio is a Blaupunkt. There are a bunch of numbers on the tags and I don't know which is which but they read as follows:
6512-6-909885
BP0273 39990815
FD043
7 640 273643
39990815
Then by the upc code there is this:
BP0273399908158841
Dang! That's a whole lotta numbers!
I hope you can help me with this.
Thanks so much!
Username: Katielegs
Im looking for a code for my Blue spot cd stereo
The BP number is 117213149864. I've been told there should be an X in there somewhere?
Username: Hay88
Post Number: 1259
Kangiska
if its a four digit code then 8841
i just notice at the end off your second number is the code to so it is more than likey four digit.
but if you need a five digit code then
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Hay88
Post Number: 1260
Katielegs
try code 4116
if its a TRAVELPILOT then 7179
Username: Acrididae
Hi,
Just bought a replacement VW Premium 6 double din head for my 2002 jetta. Stereo's serial number is VWZ9Z7B0061213. Model number is PU2354A-A.
Thanks in advance!
Post Number: 4330
acrididae
Username: Acrididae
Posted on Wednesday, June 30, 2010 - 07:42 pm:
Hi,
Sorry....Main VW Dealer or Radio Decoding Service only for this VW Clarion radio
Username: Raperce
Hello again
I need code for Blaupunkt
Type: CAR 300 (D)
No. 90 532 620
GM0300W5228316
7 647 852 320
greetings
Username: Hay88
Post Number: 1261
Raperce
code 1901
PayPal donations to my Code Calculator Software Fund are always most welcome payments to: codehelp@hotmail.co.uk
Username: Jiminy_cricket
hi there, im new here and i was wondering how do i find out my radio serial code?
Username: Hay88
Post Number: 1263
Jiminy_cricket
you need to remove the radio and post all letters numbers.
Username: Fatlee
could someone please help need code,
SERIAL NUMBER CL0410Y0060477
THANKS IN ADVANCE
Username: Hay88
Post Number: 1271
Fatlee
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM
Username: Natalieshaw
I have a 1996 Acura Integra, and its stereo is without a radio code... I could definitely use some help since a long commute makes this unbearable! Here are all the numbers I could find... Fingers crossed and thank you!
Make: Pioneer Electronics Corp
Serial No: PF 16442
Model: 39100-ST7-A000
Post Number: 4333
Natalie
Posted on Thursday, July 01, 2010 - 02:42 pm:
Serial No: PF 16442
ACURA RADIOS
If you can provide the necessary information then your ACURA code is available here for free
https://radio-navicode.acura.com/?src=inq
If not then the code will only be available from your local Honda Dealer or a Decoding Service ...who will plug in a laptop to read/recode your memory chip (EEPROM)
Username: Bu_zz2020
Hi would you be able to help me find a radio code for a philips stereo in a renault megane
S/N RN259FY0204561
4 digit code is T0X853
also got 7700434422TX852 on the label
Username: Mrp100
Hi Can you help. I am looking for a code for a grundig stereo from a seat.
s/n SEZ2Z6Y2414683
Thanks.
Username: Hay88
Post Number: 1275
Bu_zz2020
your code IF x853 = 2173
if x852 = 2103
SO PLEASE CHECK
Username: Hay88
Post Number: 1276
Mrp100
Sorry ...not in my database
Try emailing
Mention this forum
Username: Bu_zz2020
Thanks hay88.
Worked a treat
bu
Username: Eddykeys
I need the radio unlock code for my 93 mercedes 300ce am/fm cassette with cd changer in truck. Can someone help? I'll pm you whatever numbers you need, just tell me what and where to find them if not the serial # for the vehicle....
thanks in advance
Username: Hay88
Post Number: 1282
Eddykeys
send me all the info off of the radio to see if i can help you.
you will find the main number stamped into the metal casing.
but sent all letters/numbers
Username: Luckyno12
Someone please help me find out my radio code. my battery died the other day and when i went to replace it i found out my radio wasnt working. after doing some research i realized i need a code which i cannot find anywhere. Acura dealership wants to charge me $50 for the code. PLease somone help mee. I have an 2003 Acura 3.2TL. The radio serial number is U3005 L6689. Thank you so much in advance.
Username: Hay88
Post Number: 1290
Luckyno12
ACURA RADIOS
Username: Jam20
need code for my nissan almera?
Hi,I have a Nissan almera and just had a flat battery. could you pls help me the code. The model no is PN-2424M Serial no is CL052930106148 and the Nissan Part no is 28185BN800. Thanks in advance for any help!
Post Number: 4355
jam
Username: Jam20
Posted on Sunday, July 04, 2010 - 01:33 pm:
Sorry....Main Dealer or a Radio Decoding Service only for this code
Username: Monkeypog
Hello, I'm a bit stuck trying to find a code for my stereo if anyone can help that would be most excellent.. Its a Philips stereo in a renault clio, Model No: 22DC461/62E, Prod No: FD0999072139839, Serial No: RN461FX2199899.
Thanks very much if you can help.
Username: Dynamoman
Hi could the code for my radio in my corsa be located radio is a blaupunkt car 300 nos i can see are 90533422 car 300-E other nos are7648852320 also gm0300x9421898 many thanks Rob-H
Username: Hay88
Post Number: 1306
Dynamoman
try code 0856
Username: Hay88
Post Number: 1307
Monkeypog
hi post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio on bottom of label
Username: Monkeypog
Hay88
The number i think you need is: 7700 433 074 W892 although, just to make things interesting, there is another bar code with a different ending 7700 433 074 L406
Thanks
Post Number: 4359
Paul
Username: Monkeypog
Posted on Monday, July 05, 2010 - 06:27 am:
Try code 3104
Username: Qbanet
please help , I need radio Code to my renault Clio 1.6 2003
I have only VIN number : VF1BR1B0A35242737
Username: Hay88
Post Number: 1312
Qbanet
sorry radio need to be remove for code from here.
you need to remove the radio to get the info
they are to small holes each side of the radio.
use long nails.darts old metal coat hanger, very small screwdriver. put into hole about 4-5cms.
and push outwards sideways and carefully pull the radio forwards.
you must do the holes on the same side at the same time.
then post the numbers/letters from below the main barcode
off of the radio.
Username: Ribasaurus
I have a 2003 Acura MDX that I purchased last fall. Just changed the battery and found that we have the NAV code but not the radio code.
I tried https://radio-navicode.acura.com/?src=inq but it is not working (my guess is that they still have the former owner's contact info even though we've entered it into Ownerlink 6 months ago)
The serial# is U3000 L0023
Any help would be greatly appreciated.
Post Number: 4362
ribasaurus
Posted on Monday, July 05, 2010 - 06:42 pm:
Username: Theotis1957
Seattle, Wa USA
Hi I have a 1995 Saab I need the radio code for.
PU 9716A
FCC ID AX2PU9716A
YS 4929R2019049
Thanks
Post Number: 4363
Theotis1957
Seattle, Wa
Posted on Monday, July 05, 2010 - 09:25 pm:
PU 9716A
FCC ID AX2PU9716A
YS 4929R2019049
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Username: Zeevbob
Hi everybody
Could you please help me to find code for the radio on my Audi A4 1996?
The radio info: Model-Audi Delta
S/N (on the side of the radio body): AUZ1Z4S6039525
S/N (on the sticker on the radio): AUZ1Z4U6039525
Thanks in advance for your time and waiting for your responds
Vlad
Username: Superslemmet
Wow, you guys here are very helpful.
I got a VR300 Volvo radio
S/N 89FATLM142920187
Model 21001521
P/N 202612221
It came with the car i bought (Ford Orion), and the code i got doesn't work, and I can't find the previous owner. I think he has died sadly. :/
Username: Lowbattery
Hello everybody,
I will be delighted if someone can give me the code for my radio, installed on a Honda Civic 2003. The battery went down and now the radio is locked, the previous owner haven't got the code Sad
I've got the serial number through the pressing of 1 and 6 buttons on switching on, and it is
S/N 30002663
Thank you very much! Smile
Username: Lowzer
Please help me to find the Code for my autoradio Renault CLIO 2003 "PHILIPS"
radio model and serial number :
Model No: 22DC278/62B
T0R992
RN278F3045612
PROD NO: FD0403170454612
8200057681TR992
l 8200 057 681 l --C l
Username: Hay88
Post Number: 1322
Zeevbob
i have emailed you
Username: Lowzer
hay88
THANK YOU
BUT I HAVE TRIED THIS CODE : 8079 AND THAT NOT UNLOCK MY AUTORADIO
Username: Hay88
Post Number: 1325
Lowzer
R992 = 8079 SO PLEASE CHECK NUMBER.AND WHEN ENTERING
YOU MUST HOLD AT END TO STORE CODE.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Lowzer
Post Number: 7
THANK YOUUUUUUUUU
IT'S OKAYYYY
Username: Arcticsun
VW Gol
Blaupunkt Radio
5U0035119B <--possibly S/N
VWZ4Z4H9020358
Username: Jnewton
Hi there, can you help me?
I have an '02 Renault Scenic and need a radio code thanks to my local garage leaving the battery out for too long!
Model number - 22DC259/62P
Product Number - FD0501430320890
There is another number
TOX607
RN259F10320890
I would be eternally grateful if someone can help me with this
Jay
Username: Gunafan
Good evening all. Unfortunately as part of a clutch change today my battery was disconnected and my Renault Laguna 1 Philips CD/radio is asking for a code. I do not have that security code and have seen reading the replies here that there is a Magician(s) able to supply one hopefully. The details are: 22DC481/62, FD0898359002200, Barcode-7700 433 070 N564. My thanks in advance and hope you are able to assist, Regards, Harry
Post Number: 4372
arcticsun
Username: Arcticsun
Posted on Wednesday, July 07, 2010 - 11:59 am:
VW Gol
Blaupunkt Radio
VWZ4Z4H9020358
Sorry...Main VW Dealer or Radio Decoding Service only for this code
Post Number: 4373
Username: Gunafan
Posted on Wednesday, July 07, 2010 - 04:07 pm:
Try code 2 4 3 9
Post Number: 4374
Jay
Username: Jnewton
Posted on Wednesday, July 07, 2010 - 01:30 pm:
TOX607
RN259F10320890
try code 2 3 1 0
Username: Jnewton
Regrooster.....you, Sir, are a genius.....what a star!!!! I think I love you xx
Username: Gunafan
Well. Wow! Thank you muchly Reg Rooster. That code worked immediately. Am I able to make a paypal donation to show my appreciation? Keep up the great work. Regards, Harry
Username: Arcticsun
Hey Reg,
I lied, my radio is a Famar (Delphi) I believe.
Delphi P/N: 10040990
5U0035119B
014VWZ4Z4H9020358I
I hate SA things already! We bought this vehicle and had it shipped to the US from Brazil. Mistake. Cant get any parts or help.
Post Number: 4375
arcticsun
Username: Arcticsun
Posted on Wednesday, July 07, 2010 - 06:01 pm:
Hey Reg,
5U0035119B
014VWZ4Z4H9020358I
Try emailing
Mention this forum
Username: Yearsold
Re: Security Code for Philips Car Radio/Cassette Player [1992 Ford Falcon GL EBII]
G'day People,
My name is Bill and my Battery on my 1992 Ford Falcon GL EBII has been laid to rest.
My Philips Car Radio/Cassette Player now requires a SECURITY CODE and I cannot find one. Can anyone please help me.
Some additional details are :
Model No. DC600/700
Serial No. 4060745
Ford 91DA-18B865-AB
SV 009212
Many Thanks,
BILL
Username: Hay88
Post Number: 1331
Email
and they might be able to help
Mention this forum
Username: Suavegav
hi i need a code for my peugeot
serial:cl040140969474
model: pu 2294a
Username: Hay88
Post Number: 1343
Username: Mudvaynemx
Could some one help me to get my Ford Ka code ???
Serial No. 0005303
Mod. C0SH2300F-01
Thanks in advance for ur help
Post Number: 4391
MudvayneMX
Posted on Saturday, July 10, 2010 - 12:40 pm:
Serial No. 0005303
Mod. C0SH2300F-01
Try emailing
Mention this forum
Username: Equuleus
San Francisco, CA USA
Greetings,
Please help. My car battery died and I'm codeless & clueless as to what the code may be. I retrieved the following info from the Blaupunkt CD.
7 640 273 342
6512 6 909 884
BP0273 Y 8201355
FD360 INDEX 41
Y 8201355
Thank you very much.
Equ
Username: Hay88
Post Number: 1344
Equuleus
try code 8877
if its a five digit code you need please.
Try emailing
Mention this forum
Username: Hay88
Post Number: 1346
Username: Equuleus
Thank you hay88. I'll try it tomorrow morning.
Thanks again
Username: Beal2888
need code for 1999 honda pilot radio
serial number - m98d233152
model number - cq-jh5810z
Username: Hay88
Post Number: 1362
try here
Username: Roco
Hi i am after the code for my saab car radio it is a clarion PU2135A
ser No YS0331W1017474
car vin no YS3DF58B6W2065282
I need this after fitting a new battery
Many thanks
Username: Drdna600
Hi Guys.
I need code for my Renault radio:
22dc279/62E
prod: fd0101380022543
sn: 8200063200TT364
Thanx 4 Help
Username: Aep247
Hello all,
I have been without a radio in my 1996 Isuzu Oasis for about 3 years now and I was hoping someone can help me retrieve the 5 digit code.
The dealership gave my mother several numbers and I am sorry because I don't know how to distinguish between them.
Serial number: PH00122
And maybe?: 39100-S53A000
4(39101 - S53 - A01)
Thanks for all the help you have given.
Post Number: 4407
tinker
Username: Roco
Posted on Monday, July 12, 2010 - 01:37 pm:
Sorry....Main Dealer or Decoding service only for this code
Post Number: 4408
aep247
Username: Aep247
Posted on Monday, July 12, 2010 - 03:40 pm:
Hello all,
Try emailing
Mention this forum
Username: Aep247
Reg Rooster, thanks for the super quick response though. I appreciate all the help you have given.
Username: Hay88
Post Number: 1365
Drdna600
your code 6699
Username: Tahiru2888
I want the radio unlock code for my Honda ridgeline 2007. the details are
VIN: 2HJYK16287H508259
39100-SJC-A001
30008283
FF008283
DEH-M7147ZH
Post Number: 4419
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Drdna600
Thanx a lot Hay88!!! You a lifesaver!!!!
Username: Mickfinesse
Hi there
I have just purchased a 1998 Ford Finesse. The radio needs a code can anyone help me please?
Serial No. M114351
Thank you in advance
Post Number: 4422
Mick
Posted on Tuesday, July 13, 2010 - 06:33 am:
Hi there
Serial No. M114351
try code 4261
Username: Mderge
Changed Battery in Porsche Boxster - Need Code Please
Model CR210
Serial Number V5004873
Username: Hay88
Post Number: 1367
Mderge
four digit code if its a becker try 6970
if not please post the main number that can be found stamped into metal casing on the radio.
Thank you Reg Rooster.
Unfortunately the code did not work as it locked the radio for a further 30 minutes.
I dont think I idid it wrong as I entered the code via the buttons.
Username: Hay88
Post Number: 1369
Mickfinesse
your code should be 8269
Username: Tross
Just bought a Becker radio from ebay and the vendor says he doesn't have the radio code. Wish I had known that BEFORE I purchased the radio.
The only information I can find was on a narrow rectangular piece of paper stuck behind the removable front part of the radio:
0754518 621 257
U 000 2516
Any help would be most appreciated. Thank you.
Username: Marsbeck
I lose my autoradio code.
Numéro d'identification: FV1BG0G0625258544
Thanks a lot.
Post Number: 4434
TRos
Username: Tross
Posted on Thursday, July 15, 2010 - 09:59 pm:
0754518 621 257
U 000 2516
coulio
Username: Marsbeck
Posted on Friday, July 16, 2010 - 12:33 am:
Thanks a lot.
Try emailing
Mention this forum
Post Number: 4435
Mick
Hi there
Serial No. M114351
Sorry...typo error
Correct code is 8 2 6 9
Username: Hollib
Hi, I just bought a Volvo and I need the radio code. Any help would be appreciated.
VIN YV1LS537W2527027
Post Number: 4440
Brendan
Username: Hollib
Posted on Friday, July 16, 2010 - 12:01 pm:
VIN YV1LS5372W2524027
Most Volvo codes are NOT available on these forums
Try emailing
Mention this forum
Username: Marsbeck
Can anyone help me to retrieve my autoradio code:
I found These informations on my autoradio(renault):
MODEL NO: 22DC279/62E
TOY932
RN279F10019550
PROD NO : FD0101350019550
8200063200TY932
Thanks for your help.
Username: Hay88
Post Number: 1415
Marsbeck
your code 1076
Username: Marsbeck
Thanks a lot Hay88, it work.
Username: Mkampstra
Searching for radiocode:
Becker Indianapolis BE7921
SN: 55001729
Kind regards for finder
Username: Hay88
Post Number: 1418
Mkampstra
try code 12233
