hi there need a code for my senic PRO FD0204270016524 MOD RENRCW131-10 8200300855 TK 092 R092 TRIED TO FIT A BLUETOOTH HANDS FREE FROM MY OLD CAR NOT WENT WELL LOL
Marke888 hi post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
Posted on Saturday, August 14, 2010 - 07:10 am: hello
I need a code for my renault scenic (2001) diesel,but where I have ti look for this barcode,security code etc.. where can I find these? ===================================================
The radio will have to be removed from the car dashboard .
Then quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Posted on Wednesday, August 18, 2010 - 05:27 pm: Hey there, Looking for the code for my grand scenic radio stupidly removed the fuse looking for the heater fuse...............
numbers on sticker on side are as follows
RNRC3760003735 RENRCW231-10 FD0106140003735 BARCODE: 8200444069T BOX NEXT TO BARCODE X986-SECURITY ============================================= Duplicate post...Already answered
Why post the SAME request in two different threads?
dont mean to be a pain but in my first post which you successfully gave me the code for and i do appreciate it was for my tape deck, i went out today and purchased a cd unit from my local scrap dealer and hence the second post, you have flagged it as a duplicate but all the numbers and even the explanation as to why i require the code are different, would appreciatte it again if i could get the code for the new unit...............cheers john
Posted on Thursday, August 19, 2010 - 08:00 pm: Can anyone help me withe the code for my radio ,serial number : VWZ5Z6R0124022. THANKS . =============================================
TRIPLICATE post of the same request..Already answered.
This code is ONLY AVAILABLE from your VW DEALER or a Radio Decoding Service
It will not be available for free from anywhere on the Internet
