Sada... what is the best way to delete unwanted chnls on nano2
Username: Lomna
Sac, Calif U.S.A
Post Number: 1187
I deleted chnls one by one by going at chnls manager, but they are coming back. Am I doing a wrong way ?
Need advice please ...
Username: Lomna
Sac, Calif U.S.A
Post Number: 1189
Press Menu
2. Using right arrow on remote, select Installation
3. Highlight Channel Search
4. Press OK (Enter Password if set up to have password) (0000)
5. Press Red button (TP Edit)
6. Select Satellite that you want to add/edit/delete a tp by highlighting Satellite then press OK
6. Scroll down/up to the Satellite you want then press OK (It will bring you back to the Channel Search )
7. Green button is for adding TP; Yellow button is for TP delete
Sada, It doesn't work for me. At chnls delete option, buttons( red,green, yellow, blue) do not react at all.
The only thing work for is.. highlight the chanl , press Ok. A recycle icon front of the chanl comes on. Have to repeat one by one all the unwanted chnls. After all this I get out, I see all the chnls still in the guide .
Username: Mrgreg
Post Number: 517
You have to push the blue button after you have marked all channels you want to delete to finish the process.
Username: Lomna
Sac, Calif U.S.A
Post Number: 1190
Yes...I got it. Thank you brother.
Username: Mrgreg
Post Number: 518
You are most welcome devin.
Username: Saqeeb9000
Post Number: 7149
sorry saw ur message late. thx greg..
Username: Lomna
Sac, Calif U.S.A
Post Number: 1193
It is ok sada. It worked for me as greg suggested.
Thank you both.
Username: Cntrlaltdel
Post Number: 316
By the time I delete french, spanish, religious, shopping and unavailable channels... I usually only have about a 100 left!
Username: Lklives
Post Number: 16369
Username: Plymouth
Post Number: 14261
Username: Alladdin1
Post Number: 7
credit to mavrick
Go into Menu then Channel Manager, scroll over to the Delete Tab, select the delete-mode you want (Channel or Sat) with the "yellow" button on remote.
For "channels".......scroll down to the one/ones you want to delete, press ok on each (icon will change) then press "blue" button on remote to delete.
For "sat"........when you switch to sat-mode hit "ok", all channels will be selected (icon will change on all channels) then press "blue" button on remote to delete entire sat. The sat that's selected will be which-ever sat you were watching before you went into the Menu
