There hast to be a cheaper way.
Username: Gcs8
Atlanta, Ga
Post Number: 1079
https://www.dcpowerinc.com/alternators/toyota/2004-2010-toyota-camry-250-amp-hig h-output-alternator.html
thats all i can find for my car right now..... that kindof breaks the bank for me.
Username: Gcs8
Atlanta, Ga
Post Number: 1080
http://powerbastards.com/proddetail.asp?prod=Fitzall-220
well this to but i have no idea if it will work right for my car.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 641
Excessive Amperage? Ohio Generator? Ive heard good things about these alts as well,but yea the $530 seems a bit much.
Username: Mystre
Pemberville, Ohio USA
Post Number: 304
death, contact Mike at powerbastards, that's where I got mine. Just tell him all that you can about your car and engine. They should be able to help you out.
Username: Gcs8
Atlanta, Ga
Post Number: 1082
have you clamped your alt? does it do rated power?
Username: Mystre
Post Number: 306
No, I totally forgot about that. How do I do that? Sorry, new to the HO alt. thing.
Username: Gcs8
Atlanta, Ga
Post Number: 1084
you would get a power clamp from home depot or your place of choice. there should be an option that tells you what the alt is putting out in DCV.
Username: Mystre
Post Number: 308
Talk about a cheaper way. LOL Those things are expensive. Luckily I have some connections to borrow something like that.
