Sundown SAZ 2500 not working properly
Username: Aj1218
Post Number: 72
Just got my 2500d in and sound is low and distorted from my single 15" fi btl. I tried to hook up the rca's differently but is still very low even if the volume on the headunit is turned up quite a bit. What could be the problem?
Username: M_kimmel843
Post Number: 211
How do you have your gains set on the amp? Maybe your rcas are bad or going bad? Is your box big enough for the woofer? I'm assuming you've checked all your HU settings.
