Jensen VM9512 No Radio Stations, Only Static
Username: Gstreif
I have a Jensen VM9512 that will not tune into any radio stations, every other source is fine, just not radio/tuner. Any suggestions?
Username: Illuminator
Post Number: 5360
Did it ever work?
Did you hook up the antenna plug to the head unit? Dumb question, but it happens.
If not, your tuner might have gone out on you. Which doesn't surprise me since it's a Jensen.
