My nfusion hd is not detecting 119 and 110. The viewsat is detecting both birds and giving S:77 and Q:86 with same settings. But Nfusion is only detecting S:21 but no Q(uality). What could be the problem?
I don.t believe there is any problem. what you should do is to ensure after loading latest working bin, you also load the latest transponder file dated July 13, 2010. Also to remember after loading transponder file, when prompted to press OK. don't select OK, instead use the red power button on the remote to reboot the box. After all that process go ahead do your settings and scan the 110/119 birds, you may not notice any quality on some of the transponders, disregard that and scan you will get channels.
Thanks Iroy tipit. I did it many times, but no signals. However, when I download factory file and try to search signals. It gets 86% of 119 and 110. However, when I download July 12 file, it did not detect signals. Even July 13 transporders are not detecting any signals.
