ok i have 2 dual 4ohm re se i wanna run 2k on them i have a 3rd sub but if two does it no reason to add the third. i have an aq 1200d and this is what i am thinking of doing. 1 get another aq 1200d and put one on each sub or strapp at 2.6.. option 2. autotek Mean Machine 2000 Option 3 soundstream pcx 2000 or pca 2000 4.. hifonics bx2200 5... power acoustik bamf 5500 6... save money buy an aq2200 or soundstream dtr 2200 also i have aline converter do you think i amlosing sound(dbs) cuz of using a pac trunk loc(line converter)should i get a line driver? any opinions would be appreciated? also i have heard strapping is good for comps but not for daily any truth?
yes i plan on running a couple kentiks to get by on before i upgrade my 130 amp alt i ve seen people run more than 2 k on a smaller alt with batts im going to do it just temp till i get a bigger alt
Okay, because those batteries won't last long before that alt. goes out. Get that alt. as soon as you can. Also, I'd go with the Audioque AQ2200D, just a personal preference.
