Code for Radio for bmw z3 2000
Username: Joelsama
I buy a used car without battery, i buy a new one but the radio doesn`t work, appears "code wait" and i cant do nothing. i need help to fix it.
Thanks
S/N: BP0273 2 9976047
Model 7 640 273643
Username: Hay88
Post Number: 1392
Joelsama
if it a four digit code then 4952
if you need a five digit code then Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
leave turned on untouched until it resets itself.
