Cdr 500
Username: Jack28
hi need code for cdr 500 plz help
90123000018100
00304082282243
seimens vdo 330886636
no. 24469302
cdr 500(e)
2f4
Username: Regrooster
Post Number: 4368
Unfortunately the majority of SIEMENS/VDO codes (including your CDR500) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
