Peugeot CLARION PU-2294A CODE
Username: Picasso123
Hi, I lost my radio code and unfortunately had to chage my car battery. Can anyone help me? Clarion PU-2294A
SN/ CL0401Y0103638 Thanks.
Username: Regrooster
Post Number: 4316
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Username: Burko18
Hi,
I have the same problem as posted above but on a Peugeot 306.
Clarion Stereo.
PU-2294A
s/n CL0401Z0571489
bar code: C 7000000 4526
can anyone help?
Thanks
Username: Hay88
Post Number: 1316
Burko18
try code 5154
Username: Burko18
Thanks hay88, code worked.
Radio and CD player now working.
You're a star, thanks again !
