Help!
Username: Thckcrmlbeauty
i have a sound symstem with the center console and two speakers.....I want these speakers hooked up to my TV to have PS3 surround sound....this Tv is PS3 only .......The speakers have speaker wire....and a blue a/v cable that ive never seen....i am new to this.....only thing ive done is hooked up a deck and speakers in mah car....outside of a cars mechanics and (minmal) electronics...i have no idea
Username: Vm8444
TorontoCanada
Post Number: 237
not sure of your equipment how about model num,bers of everything you own.
well i got this AIWA NSX-A959 system.... and the TV is a RCA 27F520T and a ps3 2 port model
Username: Vm8444
TorontoCanada
Post Number: 239
how about inputs I know the rca has 2 inputs for audio left and right..
Im not sure what inputs the aiwa has ..
here 's the manual if it doesn't have any your out of luck
http://www.retrevo.com/support/Aiwa-NSX-A959-manual/id/1076ci360/t/2/
you can connect ps3 to tv directly easily with component cables red,green blue to tv input for video and red and white for audio but you
must have inputs to go through stereo..
or else upgrade I say these 2 are inexpensive..
http://www.dakmart.com/p11039/SLD-DENON-AVR-589-HOME-THEATER-RECEIVER-HDMI-1-3A- W-WYT/product_info.html
and
http://www.dakmart.com/Audio-Home-Audio-Home-Theater/c4_9_10/p11311/Boston-Acous tics-Horizon-Series-MCS100-MDNT-5.1-Speaker-System/product_info.html
this combo will sound like a 2000 dollar home theater
theaudioguy.ca
