Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press buttons 6 OR 5 to store. for 10 seconds
Posted on Friday, March 26, 2010 - 06:04 am: Edit Post please help had to replace battery but couldn't find code in book for radio now Renault want £25 for them to retrieve my code (HELP I'M GOING INSANE)
MOD-RENRDW100-10
RNRD0140232873
PROD No FD0504460232873
BAR CODE No 8200247962TW039 ======================================================
Posted on Saturday, March 27, 2010 - 07:35 pm: Edit Post hi all need radio code for laguna 02 due to leaving lights on and got a flat battery model no 22dc27962z toe 853 prod fd0101370146470 ============================================
hi Maciosstrzala your code is 4690 how to enter below
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
note the radio does not lockout after a wrong code entry it only doubles the time to wait before the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
Hi, Thanks for reading. My battery went flat and lost my radio code and it isn't written in the manual!!! I paid £15 for the code doesn't work! company isn't interested!!!
derbysatellite New member Username: Derbysatellite
Post Number: 2 Registered: Apr-10
Posted on Saturday, April 10, 2010 - 06:23 am: Hi, Thanks for reading. My battery went flat and lost my radio code and it isn't written in the manual!!! I paid £15 for the code doesn't work! company isn't interested!!!
Hi there. Usual story had to disconnect the battery to do repairs and lost the radio code. Any help i would be eternally grateful
sorry i suck at art and forum things, did not know how to reduce the pixel size on the pic. But a photo of the stereo label is here: http://img341.imageshack.us/img341/7690/picture012ig.jpg
hi civic2006 sorry i cant do this one but. IF YOU HAVE THE FULL DETAILS OF THE ORIGINAL OWNER OF THE CAR IF ITS HONDA,THEN YOU CAN GET IT FREE FROM HONDA JUST GO TO: https://radio-navicode.honda.com/ or take alook here. http://www.nairaland.com/nigeria/topic-306281.0.html
Renault Laguna 2003 hello I've changed battery and now my radio code required! well please help me! MODEL NO: 22DC2 79/62Z TOG924 RN279F20363279 PROD NO: FD0202390363279
RNRD0130063553 Taxidriver New member Username: Taxidriver
Post Number: 4 Registered: May-10
Posted on Wednesday, May 12, 2010 - 12:02 pm: Model number renrdw100-10 too986 rnrd0130063553 prod no fd0003210063553 help please flat batt no tunes 7938 don't work thanks ==================================================
hi there, where can I find the radio's serial number or ref number in order to post on here? Happy to make a donation just a bit hopeless with these things!}
Posted on Friday, May 14, 2010 - 10:42 am: hi there, where can I find the radio's serial number or ref number in order to post on here? Happy to make a donation just a bit hopeless with these things!} ==============================================
Sworth26 hi your code 9968 hoe to enter below. IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and HOLD the [ ] button for up to 10 seconds to store the code }}
similar issues on my side after a battery change I have a 2003 Laguna II estate here is the information I have found regarding my car: MRE5304CA967 VF1KG0R0628520355
hi post the numbers/letters from below the main barcode something like 7700xxxxxxtt123 or 8200xxxxtt123 or the security code like Q123 or T0U123 can be found in a small box then i can help you off of the radio
Hi guys, I would like to ask you to find the radio code for me. I was playing with my system and I restarted it and now it is asking for a code that I don't have My VIN is:
Posted on Sunday, June 13, 2010 - 02:24 pm: Hi guys, I would like to ask you to find the radio code for me. I was playing with my system and I restarted it and now it is asking for a code that I don't have My VIN is:
VF1BGCZB636162660
============================================= The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Here is a video showing how to remove a standard radio from the dashboard. A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These can be unscrewed using the appropriate size of Allen key. ====================================================
Yes, you are right, for Laguna I it is relatively simple but I have Laguna II, phase II and the audio system is carminat DVD + cabase Auditorium. The radio unit is hidden somwhere in front of passanger in the dashboard, on the front panel there are only the buttons and the display- in brief. I have found the way how to do it here:
Posted on Wednesday, June 30, 2010 - 09:17 am: hi reg rooster looks like your the Man im too after a code for my laguna 1999 Model no:22dc461/62e Prod No:FD0999062126680 =========================================== There should be a 14 character Serial Number beginning with RG or RN or PH or similar (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
RENAULT Clarion Radio =============================================== ==================================================
Have you tried the numbers printed on the second label as they may be your codes
7450 and 6998
If not, then as the code given by the Main Renault Dealer does not work then you will have to use a Radio Decoding Service who will connect a laptop to read the working code(s) inside your radio`s memory chip (EEPROM)
_martin_ have you tryed that radio : 7450 and cd changer 6998 and whats the number at the bottom of that sticker please. only clarion with a barcode starting with C7 Can be done by serial.
I have tried both codes - they do not work. The number at the bottom of the sticker is my VIN (already posted). I will use any decoding service. Funny is that I don't know if the code for radio is needed. The car says on the display "INSERT THE CODE" but there can be a GPS code, chnager code or a tuner code (if these codes are not the same...)
Anyway, many thanks for your help. I will then write how I did it to help the others.
