Total noob question
Username: Mystre
Pemberville, Ohio USA
Post Number: 203
Okay, I am wiring my subs to my amp and I have a question. My amp has 2 sets of inputs for speaker wires. It is a Nine.1. Which one of these diagrams would be correct? Thanks all!
http://i161.photobucket.com/albums/t227/nyoc2020/wiringdiagram1.jpg
http://i161.photobucket.com/albums/t227/nyoc2020/wiringdiagram2.jpg
Username: Rovin
1 15 = 153 DBs ...Trinidad & T...
Post Number: 16436
does not matter which + or - terminal u use since inside the amp both are connected together
they just put 2+ & 2- connections for convenience ...
Username: Gcs8
Atlanta, Ga
Post Number: 759
it lets you wire par or series at the amp, but just pick the pos and neg you like best and use those 2 holes.
Username: Mystre
Post Number: 204
Okay, I totally messed this up. Here are the pics I meant to use. Please tell me which one of these are correct. I just want to make sure I hokk them up correctly. Thanks.
http://i161.photobucket.com/albums/t227/nyoc2020/wiringdiagram1-1.jpg
http://i161.photobucket.com/albums/t227/nyoc2020/wiringdiagram2-1.jpg
Username: Gcs8
Atlanta, Ga
Post Number: 761
should be able to use eather.
